Height difference between truck injectors (LQ9) and LS3 injectors?
Right now I am running a modified truck rail (drilled/tapped on each end for -6 fittings) along with stock LQ9 injectors. All of this is on-top of a LS6 intake that I made custom hold-downs for.
I recently acquired a set of LS3 injectors and am wondering how much shorter they are then the LQ9 injectors. The LQ9 injectors I believe are shorter then the standard LS1/LS6 injectors, how much shorter are the LS3 injectors versus the LQ9?
Thanks in advance,
James
Thanks in advance,
James
Thanks in advance,
James
Thanks in advance,
James
http://www.corvetteinjectors.com/sho...?productid=366
