What kind of fuel system needed for 550rwhp
Old 07-26-2011, 09:26 PM
headed-ws6's Avatar
Default What kind of fuel system needed for 550rwhp
As stated What do y'all think I need? This will be on a single turbo car with a forged bottom end ls1. I don't plan on upping the boost any as i will run about 8-10 pounds. just looking for a decent price fuel upgrades to keep my engine happy.
Old 07-27-2011, 08:39 AM
Ollie8974's Avatar
The Racetronics Fuel pumps supplied by the vendors who support these fourms. They are direct replacement for your application.
Old 07-27-2011, 09:20 AM
deatschwerks's Avatar
You'll need about 52# of fuel from each injector once you are in boost.
I'd recommend a set of our 60# injectors. ...and hey, we just started our Modern Muscle promotion yesterday, so you picked a good time!
Old 07-27-2011, 09:22 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Feel free to give me a call & I can set you up with the proper pump setup to support your power goals.
Old 07-30-2011, 03:39 PM
1lejohn's Avatar
Using the Racetronix with the hot wire kit. Custom Summit rails with a y block that feeds into both sides of the rails using #6 an line with the pro lite type of braid. Cross over on the front of the rails. Running the Fast 57lb injectors. Connected the an line to the factory hard line with an adaptor. We hold a steady 60psi.
