Problem, please help: Fuel pump and filter location, and how to replace? 2000 C5
After car running like crap and dying out quickly, I check the fuel pressure at the rail. Reads 11 to 14 psi. Car fired up and pressure quickly drops to 9-10 psi and dies out. I'm guessing a bad fuel pump and/or filter. My question is, where do I find the fuel pump and filter? And how to replace them? Also, please post any other areas where a problem may be. Thank you.
LS1TECH Sponsor
Based on your signature, this is a C5 Vette. If so, the tank does not have to come out....
It is nothing like what Ollie posted.
The pump is in the tank, but it is removed from in front of the Dr. side rear tire.
Filter/pressure regulator is further forward, easily found if you follow the fuel lines.
It is likely the pump, but if you are short on diagnostic capabilities, the filter is easy to change as a first step.
