Truck intake and rails with ls1 injector????? help
what all do i need to use the truck intake and rails with car injectors will the just replace them or is there modifications i have to do
They will not fit, the truck uses a mini delphi, while the LS1 uses a full length 60mm injector.
I do carry the truck injectors in several flow rates if you need to change them out.
