Which would yall use
Im building a fuel system for my turbo project and was going to use 2 walbro 225 intank. I have just found that Aeromotive has come out with there new stealth 340 series. I wanted to know what yall think of them compared to the 225 and which would yall pick between the 2 and why. Your input is appreciated.
LS1TECH Sponsor
If you are runing a stock regulator, you will have low speed fuel pressure issue with the larger pumps. You need to upgrade your regulator/return system & pump wiring to support larger pumps
Feel free to call for more info... I build them all the time & can set you up with everything you need.
