?FAST Fuel Injector Adapters?
2002 ws6 I have purchased a FAST 102mm intake, 102mm throttle body and fuel rails and 42 lb injectors. I need to know which adapters to buy for the fuel injectors? They have minitimer type connector kit (170599-1), USCAR type connector kit (170600-1), minitimer to USCAR type connector (170603-1), USCAR to mimtimer type connector (170604-1). These are all FAST parts. WHICH DO I NEED.
If you bought these injectors
http://www.compperformancegroupstore...Category_Code=
Then you shouldn't have to buy adapters because they are already minitimer type connectors and will plug up to the stock wiring harness.
Your engine harness should have a minitimer connector. So whatever the connector on your injector is, you'll need to convert it from that to minitimer.
I know some of the Fast injectors have a minitimer connector already, so you shouldn't need an adapter if that's the case.
