Help Ignition Relay Prob: no start and stall
Old 09-11-2011, 11:59 AM
Livloud's Avatar
Default Help Ignition Relay Prob: no start and stall
Hello there,
1. Vats deleted from pcm ( also bypass module installed, beforehand )
2. Fuel is good
3. No spark
4. Battery good
5. New alternator
6. New starter
Ive ruled that while wifey is cranking engine and I fumble with Ignition Relay there is a soft spot when positioned correctly engine fires !
If I let go engine either continues to run or will stop immediately.
At times engine stalls when driving down the road.
Please Help
bypass ignition relay ( toggle switch ) needed?
7. Starter and Ignition Relays are new
any suggestions greatly appreciated
Rob
Old 09-11-2011, 08:04 PM
Ollie8974's Avatar
Check for loose wires. Check grounds for corrosion.
Old 09-14-2011, 11:52 AM
Livloud's Avatar
Found!
Bad ground to block from starter!! & Little wear on power cable to starter where may have arcd'
Holla!
