Cost effective injectors?
Old 10-07-2011, 11:42 AM
thunderstruck507's Avatar
Default Cost effective injectors?
Pretty sure with the ported 799s and a different cam I will need to upgrade from my 28# stock injectors.
I was thinking of using the cobra injectors but now I'm reading about how they don't work properly.
What is another good budget option? I really don't have $$$$ to buy high dollar new injectors.
Old 10-07-2011, 08:46 PM
FICINJECTORS's Avatar
we offer a re sizing program $200. you send your injectors in and we can re flow them any size up to 55lb 4bar.this service also includes a rebuild new filters o rings and pintle caps.
Old 10-10-2011, 09:48 AM
777's Avatar
Do you have a core charge program for this?
Old 10-10-2011, 10:34 AM
LSJM1's Avatar
The white bosch III injectors from supercharged buicks they are 41lbs at 4bar I run them and sell them when I have extra sets of them for $10 each
Old 10-11-2011, 09:38 AM
Don't happen to have any now do you?
Old 10-11-2011, 03:50 PM
Higgs Boson's Avatar
Are you saying the Green Tops don't work correctly? Mine work great....
Or some other ford injector?
Old 10-11-2011, 04:13 PM
Blue Giant 03/04 Cobra injectors
since they are 4v they supposedly have a weird spray pattern that makes tuning them more difficult, and apparently they require adapters to use anyway
Old 10-11-2011, 04:23 PM
well, why don't you just get some green tops?
Old 10-11-2011, 04:31 PM
I am unfamiliar with them, I'll look into it. That's exactly the kind of info I was looking for.
Are they plug and play? No adapters or any issues? I'm running a stock fuel rail and a Fast 90mm if that makes a difference at all.
Old 10-11-2011, 04:42 PM
Unreal's Avatar
What about stock ls7 injectors? They support ~580-600rwhp without issues. If not 60lb SDs are a decent deal for around $400.
Old 10-11-2011, 04:47 PM
Looking to spend $200 or less. The resizing program would be a good deal but I can't go without my stockers for long enough to send them in right now, maybe later if I don't come up with something.
Old 10-11-2011, 04:54 PM
deatschwerks's Avatar
We have new, flow-match injectors for your LS1 from 35# up to 50# for $459/set of 8.
Drop-in fitment, no spacers or adaptors for the rail required.
Old 10-11-2011, 05:39 PM
I am running a fast 90 and stock fuel system except for the injectors and a fuel pump....408ci with 520rwhp and 730rwhp on a 200 wet shot.....
they get to about 65% duty cycle.....
Old 10-25-2011, 03:39 PM
Thanks for the tip!
Scored a set of 8 on ebay for $61 shipped.
Old 10-25-2011, 03:57 PM
KING Z28 HAWK's Avatar
What did you "search" for to find them?
Old 10-26-2011, 09:04 AM
"bosch 36"
"bosch 41.5"
"bosch buick injectors"
"bosch III"
They are bright white and easy to spot when scrolling through the results.
The same guy started a new auction as soon as mine was over I think, from CA. He shipped same day. If you want I will update this thread once I receive and install them.
Old 10-26-2011, 01:27 PM
98transbum's Avatar
"bosch 36"
"bosch 41.5"
"bosch III"
be very carefull with that guy on e bay.. there is a white injector that comes out of the focus.. pn is 0280155771 its the same identical one but its 18lb.. the 36 has pn 0280155811 or 868.. ask me how i know? i bought them.. turned out to be the 18lbers.
Old 10-26-2011, 04:31 PM
Thanks for the heads up I will inspect them all
EDIT: auction lists part number 0280155811
If they are incorrect he can refund me or I will file paypal claim.
Old 10-26-2011, 08:06 PM
25thhawk's Avatar
Are those a direct fit? no adapters, spacers, fit the stock rail, etc. Thanks
Old 10-26-2011, 09:45 PM
ZL1Killa's Avatar
sounds like a lot of trouble if possible issue. money sucks, but I would have just either been without or bought a new set and had no worries and spent some extra dough. Glad you were able to find some that would work for cheap though.
Quick Reply: Cost effective injectors?
