Needs some help with fuel lines
I am want to run AN line from the top of the tank of my 2000 Camaro SS to the fuel filter, and there is also another line that is plastic that runs off the top off the tank to the body also has quick disconnects (think it is the fuel return)
Could someone help me with part numbers for the (4) quick disconnects and I am guessing -6an line would be the correct size
Thanks in advance
-Sean-
Thanks in advance
-Sean-
Dorman
http://www.dormanproducts.com/docume...uyersGuide.pdf
https://ls1tech.com/forums/fueling-i...ttachment.html
This thread, Post 14,19,and 25
Kleeborp the Moderator™
Before you go all-in on the Russel quick disconnects, read this:
https://ls1tech.com/forums/conversio...-fittings.html
They've supposedly redesigned them since this problem was noted (I've had the same problem in the past), but I've lost faith in their ability to stay where they should be. Fuel isn't something I want spraying around a hot engine bay should one of these decide to let go.
