Fuel pump advice
Fuel pump advice
Im planning on running two walbro 255's for my single turbo build. I was going to run one on a hobbs switch and have both of them in tank. After doing some more searching I had found a few people had problems with the switch working. So the other plan was to run the same pumps outside of the tank and have them run all the time with a one-way valve on the feed side to the rails. which would yall do?
