No fuel pressure?
No fuel pressure?
02 silverado 5.3. Truck is getting fuel to drivers side rail, but the crossover rail is dry and no fuel pressure at check valve. The lines are clean, replaced the fuel filter and pressure regulator. Fuel does come out when you cycle the key and the line is disconnected, I swapped the drivers rail out with another I had laying around, and blew air threw the crossover tube still nothing. I've run out of ideas, any helpful input would be greatly appreciated.
