Fuel Rail Fittings
Fuel Rail Fittings
Installing a LQ4 into a buggy and was wondering how everyone plumbed there fuel lines to their fuel rails. Does someone just sell OEM style fittings for the rail side and then everyone just use AN fittings from there out? If so anyone know were to get OEM style fuel rail fittings?
Thanks,
Chase
Thanks,
Chase
Kleeborp the Moderator™
What kind of lines are you planning on running? Stainless braided lines, or nylon? If you are wanting to run nylon line, you might check this thread out, starting at post #19:
https://ls1tech.com/forums/fueling-i...ttachment.html
With the stainless braided line, you'll end up needing AN to GM quick disconnect adapters (you can find them for 3/8" and 5/16" hard lines) like the one pictured above from Russel. Aeromotive makes them as well, but are WAY more expensive.
