Will I need to upgrade my injectors?
New motor will be a 370 LQ4, Stock crank, Eagle rods and Mahle pistons at 11-1 compression, fully ported 799, ls6 intake, Ported TB, TSP 1 7/8 headers, Cam in the TSP 233/239 @ 112 Range, All ARP bolts, My question is will my fuel system, Pump and injectors be enough to handle the power? or will I need more?
Please keep comments to the fuel system I'm not asking about the motor components its what my builder suggested. I do know I'm losing power with the intake but its what I can afford now.
This will be a direct plug and play. Also will give you room to grow. We have them new and in rebuilt. As for fuel pump i recommend a 255
http://www.corvetteinjectors.com/sho...?productid=323
http://www.corvetteinjectors.com/sho...?productid=357
Since you are running a ls6 intake. A bosch racing 42lb 58psi is the ticket.
What is the main difference between the two injectors you have listed?
