What injector for a cam nitrous set up.
02 ls1, ls6 intake, stock maf, and tb. Cam, unknown, with a built motor with a little more compression. Lets say it makes 380 ish on motor and I want to be able to spray a 175 shot through it (wet); what injector am I looking at?
Car is being put together by a friend and were peicing it together so I cant give exact info as dumb as it sounds, but I just want ball park figures. I plan to run an aeromotive 340 and I will be getting a dyno tune.
Stockers should suffice and work well with a good tune, unless you suspect a bad injector or two. Your kit is safe with that pump, so you should be good to go.
