why my injector flow rate vs kpa is different ?
Old 01-18-2012, 06:27 AM
s57_s2k's Avatar
Default why my injector flow rate vs kpa is different ?
hi
my car has 12561462 grey injector and my flow rate vs kpa is
28.15046 28.58450 29.20456 30.75469 31.12672 31.62277 31.99480 32.18082 32.36683 32.67686 32.86288 33.23491 33.79296 34.35101 35.09507 35.90114 36.76922
I got this info from my Hptuners stock tune but my friend car has the same injector, but his flow rate vs kpa is
29.14255 29.32857 29.51458 29.70060 29.88662 30.01063 30.19664 30.38266 30.56868 30.75469 30.94071 31.06472 31.25073 31.43675 31.56076 31.74678 31.93279
both cars have ls1 engine mine is 2003 and his car is 2005 .
Old 01-18-2012, 08:49 AM
Old Geezer's Avatar
You say your tune is "stock"?? Sumptin wong..
No way would the manifold pressure change the inj that much..Your bud's is likely close. Yours no way.
Old 01-18-2012, 11:33 AM
ZL1Killa's Avatar
you sure the 2005 is an ls1?
Old 01-18-2012, 02:04 PM
s57_s2k's Avatar
yes its stock , I have double check it with Tune Repository .
Old 01-18-2012, 02:06 PM
s57_s2k's Avatar
its a 2005 holden monaro .
Old 01-28-2012, 05:08 PM
s57_s2k's Avatar
since all LS engine work on 58 psi and we have the same injectors I have copied my friend injector control values .
Quick Reply: why my injector flow rate vs kpa is different ?
