how do u connect fuel lines?
Old 02-22-2012, 08:58 PM
Ws6power1's Avatar
Default how do u connect fuel lines?
When running return fuel hose how can I connect it to the existing return? O think ill have to cut the stock line to tie into but what do u use for a fitting? If I cut it there wont be any kind of barb to slip the hose over and clamp. Should I flare it and use a fitting?
Old 02-22-2012, 09:18 PM
Ollie8974's Avatar
Use these. Russell 644120
Attached Thumbnails how do u connect fuel lines?-assembly-step-1-russell-644120.jpg
Old 02-23-2012, 12:15 AM
Ws6power1's Avatar
That helps thanks
Old 02-23-2012, 12:16 AM
Ws6power1's Avatar
Do u know where to get them? Size?
Old 02-23-2012, 06:02 AM
Ollie8974's Avatar
I believe the vendors who support these forums have them.
make sure you get the new version with the threaded color, not the old style with the plastic pinch lock. This style is known to slip off.
Attached Thumbnails how do u connect fuel lines?-russell-push-efi-fitting.jpg
