Will ford 39# injectors be enough for a stroked 427?
Old 02-24-2012, 12:28 AM
venom 13's Avatar
Default Will ford 39# injectors be enough for a stroked 427?
Got a project going on, and i need to get parts together as quicly as possible. The previous owner of the long block had ford racing 39# injectors....should i bump up to something bigger? If so, what kind?
(I also have an upgraded fuel pump that i will be installing, so no worries there)
Ive been doing some reading and it seems that the ford injectors flow at a different (lower) pressure than gm injectors, so the ford injectors can actually flow beter than a higher number gm....is this true? If so, should i just keep these?
I checked out the calculator for injector sizing, but i didnt even know where to start bc im not sure of the pressures and such, so any help would be greatly appreciated.
Old 02-25-2012, 01:13 AM
venom 13's Avatar
Anyone?
Old 02-27-2012, 10:24 AM
venom 13's Avatar
Trying this one more time....bump
Old 02-27-2012, 08:04 PM
warriorcustoms's Avatar
How much horsepower will the 427 have??? my 396 ltx will be close to 600hp & im gonna use 42lb injectors with an afpr so I can bump up the pressure if needed
