what size injectors 42's or 60's
what power do you think/plan it will make naturally aspirated?
i would think 42# rated at 43.5psi (equivalent of 48.5# @ 58psi rail pressure)
i wouldn't think you would need 60s...that 408 is likely to make 550~600rwhp you think? I Would say 50# injectors would be fine.
what fuel pump you going to use?
255lph pump maxes out at 51lb/hr; I suggest a 300lph or larger for a single pump setup
