Help. I melted pistons
I recently got rid of the ls1 on 7psi of boost and went to a 6.0 on 10lbs. Single 255 pump and 60lb injectors. Stock lines and rails.
Second pass I melted 2 pistons in the 6.0, And broke ring glands on a seperate piston. Air fuel was 12.3.
I have duel pumps now, do I need bigger rails
I have the stuff for the boost referenced regulator now to hook it to the stock feed lines and make a return from the evap. Should I do this or go with 8an from the tank to the regulator and get bigger rails
