WSP330 - EL3M In-line Screw Pump 330LPH, High-Pressure
Any one use this thing.
only site i see it on is the racetronix iste. but cant find any place that someone has used it
http://www.racetronix.biz/itemdesc.a...WSP330&eq=&Tp=
thanks
thanks
I was going to pump the same question. I have two of them coming in soon, I'll only need one until I go turbo (this summer), but even then I'm debating whether I should run two with one on a hobbs switch or one on a boost a pump.
Edit: Specifically curious to see how anyone has plumbed these in an inline setup... 15mm barb inlet and 8mm barb outlet is interesting. That's approx -8AN in and -6AN out, but NHRA says you can't use hose clamps...
