what injector with fast 92 intake
Old 08-28-2012, 08:14 PM
nitroussharks's Avatar
Default what injector with fast 92 intake
can you use any style injector with a fast 92 intake,i have ford red tops and they are the fat style injector,not sure if they are seated down far enough,here is a pic,
Old 08-29-2012, 11:58 AM
ZL1Killa's Avatar
i believe you have a 14mm top O-ring and the same bottom O-ring.
as long as you have an injector with an O-ring that fits nicely of 14mm you are good. you will want to check your height, I can't remember what that is.
if you ever buy different injectors be wary of HEIGHT and your fuel rail.
Old 08-29-2012, 04:28 PM
my fuel rail doesnt sit flush against the intake thats why i was asking,anyone run this style injector with their fast intake
Old 08-29-2012, 07:56 PM
ZL1Killa's Avatar
now when you say that, are you saying the blocks that bolt down the rail aren't sitting all the way against the intake? The rail won't sit flush against the intake.
Just recently I had the fitting/piece that is in the intake that the bolts thread into that hold the fuel rail down pulled out. I got the bolt off of it, and then took some JB weld (small amount) and pushed it back down in the hole on the intake. Let it set overnight and then finish installing and it won't come out.
Old 08-29-2012, 08:02 PM
FICINJECTORS's Avatar
Fat bodied injectors don't work well on a 102. You need the newer style pencil injectors.
Old 08-29-2012, 08:53 PM
this is a fast 92 and yea the rail blocks dont sit flush with the intake
Quick Reply: what injector with fast 92 intake
