Plz help fuel pump question.
I recently purchased a vortech supercharger kit from a friend and he misplaced the in line fuel pump that normally comes in the kit. It will be running at 8lbs of boost and I have 60lb injectors. I was wondering if you could give me my options for safe fuel delivery without breaking the bank.
I would like to run a simple fuel pump booster but, I didn't know if that would be adequate enough for the job. Thanks for the help.
Car is a 01 trans am conv. 100% stock.
My question is..... I do understand that everything is rated in lbs. of boost or what have you. My main question is when I hit sixth gear in that Z28 Lt-1, will I hit 180 mph?????? Thanks for your answer.
