Need help asap e85 conversion
Old 09-04-2012, 03:50 PM
Boosted Firehawk's Avatar
Default Need help asap e85 conversion
What is needed for this build. I have a stock lt1 tank with complete pump and assembly. I also will need twin pumps for atleast 700 rwhp because it will be a boosted setup. I also need to know what else I would need to make this work?
This will be on a lsx engine platform too.
CAN I the stock steel lines to the rails or should I swap to -8 feed lines?
I will also need a return line?
fuel filter?
thanks
Old 09-04-2012, 07:21 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
A 700rwhp E85 setup is equivalent to a 1000rwhp gasoline setup as far as flow.
You will need a return line, regulator & preferrably a line upgrade over the stock steel lines.
I offer E85 compatible fuel systems for your car.
I can build a custom system to suit your needs.
Feel free to call if you want to discuss in more detail.
Quick Reply: Need help asap e85 conversion
