5.3 turbo fuel pressure gauge issue
Old 10-03-2012, 07:24 PM
'00 formula elesone's Avatar
Default 5.3 turbo fuel pressure gauge issue
the current set-up Stock bottom end 5.3 with 76mm, comp turbo cam lunati springs and good pushrods. The car is all together and i decided to go with aeromotive stealth 340, and a boost ref. fpr from murrays speed shop. The fuel pressure gauge is mounted on the regulator, and whenever I fire up the car the fpg shows "0"? the fuel system has aftermarket rails and a return to the tank. I even returned a gauge thinking it didn't work. I was hoping to get the tune dialed in this fri. but I need to know the fp to get the injectors set. btw the injectors are ev1 80# siem deka from lashway. any help or advice would be cool. the voltage at the pump is good as well
Old 10-04-2012, 06:14 AM
LILHEMI's Avatar
you actually have to turn the screw on the regulator to up the pressure.
Old 10-04-2012, 08:58 AM
Old Geezer's Avatar
If the system has enuf psi to run the engine, then the gauge should show some value. [Unless the psi is lower than the minimum gauge reading. I doubt both gauges are fubar]
How do you have the system plumbed?
As Hemi mentioned.... Have you tried adjusting the reg?
Old 10-04-2012, 02:59 PM
I figured it out. the fuel feed line has a t-block with one line returning to tank. that line must have been for the excess or like a factory return. I capped it and saw all sorts off pressure. thx
Old 10-04-2012, 03:03 PM
Yes, I understood that much. but there was no indication of pressure with the car idling. It had to have something there. Since I still had the t block near the filter in the back the pressure was returning to the tank from there. thx though
Old 10-04-2012, 03:06 PM
[QUOTE=Old Geezer;16781522]If the system has enuf psi to run the engine, then the gauge should show some value. [Unless the psi is lower than the minimum gauge reading. I doubt both gauges are fubar]
As Hemi mentioned.... Have you tried adjusting the reg?[/QUOTE
stock feed line goes to front of car where i changed over to -6 to one rail then crossover -6 to the other. finally to the fpr, then to the old evap line for the return. I did eliminate the canister for this mod. I hope the evap line does the job for the return for what my goals of 575whp are
Quick Reply: 5.3 turbo fuel pressure gauge issue
