Alittle lost on my fuel system plz help
I got a 01 ss awhile back that was boosted I planned to rob all the stuff to boosted my z28 I switch the fuel system over which was
Aeromotive a1000 pump
Aeromotive filters before and after pump
Aeromotive regulator
Aeromotive fuel rails into 60lb injectors
All N8 breaded line
My ? Is they had the regulator before the rails not after like the aeromotive web site shows the ss ran fine on it and so does my z28 should I switch it around or y would they even run it like that over the other way
All N8 breaded line
LS1TECH Sponsor
Flowing through the regulator can become a restriction at high power levels.
This is not the proper way to plumb a system but it will work in most cases.
If you look through the regulator, you will see it is not an efficient path from 1 side to the other.
If your pressure holds steady at max power level, you are fine.... if not, re-plumb the system.
