HELP!!! fuel pump trap door
I have the trap door cut to get to the fuel pump cause im changing my fuel level sending unit but the fuel pump is a twist off (unlike the video where it has
bolts) and it not budging even beating on it with a 2 pound hammer and crow bar. Any ideas to get the fuel pump to twist out?
The fuel pump is held in place with a slip ring. Tap on one of tab sticking straight up. righty tighty. Lefty loosey. This problem was discussed a while ago. Do a search of the forums. Key word Fuel Pump.
Can you post some photos, showing what you are pounding on.
