Help...What injectors are these?
Old 12-11-2012, 07:25 AM
PaSteLaSo4U's Avatar
Default Help...What injectors are these?
I bought the car with upgraded inj but want to know the size, they are red top ford jectors and read F1SE-E5A
385 on other side..Any help is appreciated, thnx
Old 12-12-2012, 03:36 AM
ZL1Killa's Avatar
SVO 30 lb red top injectors. Bosch II EV1 style. These are also likely 30# @ 43.5psi. Your fuel pressure is 58psi, so they are 15% larger. Have the tune checked to double check this and make sure they are not rated at 58psi.... I can't remember the ford stuff.
google is your friend. I searched F1SE-E5A and immediately was taken to FORD SVO 30#
From what I read, the Ford SVO red tops are rated at 39.15 psi. To get the ratings for 58psi you would mutiple 30# by square root (58/39.15) = 30# * 21.7% = 36.51# @ 58psi
Quick Reply: Help...What injectors are these?
