Recomend me a fuel regulator
any recommendations on a fuel regulator for a turbo 5.7lt, twin 044 pumps, non return system, must have x2 an6 inlets from each pump andan8/or an6 feed to the rails.
You do not do non-return systems with EFI pumps.
You need to feed the rails first & run the return after the rails back to the tank.
Dead heading the pumps will ruin them.
If you are looking for a proper fuel system, give me a call, I'll be glad to help you out.
LS1TECH Sponsor
Yes that is what a return style regulator does.... you mentioned a non-return system.
Non-return regulators (often used in carb applications) restrict the flow/pressure & deadhead the pumps.
Properly designed, you do not need a bunch of ports on the regulator.
You feed the rails & bleed off the excess presure to the tank with the regulatorl
