Ls1 to ls6 swap help
Old 01-10-2013, 06:27 AM
Suprfast's Avatar
Default Ls1 to ls6 swap help
I have a 99 Camaro with ls1 intake and plan to swap to a ls6. What if any are the tricks or complications. Is this hard.
Old 01-10-2013, 07:09 AM
HioSSilver's Avatar
Deleteing the egr is the only thing involved extra. Other than that it's a direct bolt-on.
Old 01-10-2013, 04:42 PM
Suprfast's Avatar
I's it hard to do in car. Do you loose coolant
Old 01-10-2013, 06:52 PM
justin hover's Avatar
Its pretty straight forward...plenty of write ups. You get a lot more help posting this in the external engine section.
Old 01-10-2013, 07:04 PM
transamtom's Avatar
Get new gaskets,knock sensors,ks harness,opsu and rear coolant block offs and front coolant crossover.
Don't over tighten the manifold bolts.
Make sure you stuff rags down the intake ports before you clean up the mess.
Redo your PCV lines as they are probably shot.
Change your oil when your done
Old 01-10-2013, 07:05 PM
Suprfast's Avatar
Thanks
Old 01-10-2013, 08:11 PM
Mrmooney's Avatar
Great info hopefully will be doing mine soon as well.
Quick Reply: Ls1 to ls6 swap help
