Which injectors?
Which injectors?
I'm trying to figure out what size/style injectors I should go with.
I have an '04 LQ9/T56 going into a '67 Camaro. I'm doing an H/C/I swap, and will probably be looking at 450-500rwhp. Intake is an Edelbrock Vic Jr. EFI, so I think that means I can use standard or Pico injectors. Right now the LQ9 has whatever it came with (stock) injectors.
The fuel pump will be a Walbro 255 liter/hour or possibly a 400 liter/hour pump (overkill?).
What size/style injector is recommended? Is it possible to go too large on the injector? I don't plan on spraying this motor, or going FI in the future, so I won't need a ton of room for growth. Thanks.
give a call to Fuel Injector Connection - FIC
The 32# would suite that power level fine. I would rather put in some 36# or 42# just to have a little breathing room though and they would run fine.
