Walbro, Racetronix or Lonnies/Racetronixs
Looking for a upgrade fuel pump for my '99 TA.
N/A. 686 fwhp.
What's the difference between Walbro, Racetronix and Lonnies/Racetronixs.
Would the single 255 lph be O.K.
Thanks
N/A. 686 fwhp.
Thanks
LS1TECH Sponsor
To try to clarify....
There are quite a few Walbro pumps made with varying specifications.
The Racetronix pumps are specifically modified for use with the venturi style fill bucket used in your car. No off the shelf Walbro pump is built for this application. To keep the full benefit of your factory system, I recommend using this pump.
As far as your pump needs, if you are below 550rwhp, I would say a single Racetronix pump wil fit your needs. This is typically 650 flywheel HP.
As far as my offerings, I use the Walbro/Racetronix pump kits for single & also in my dual pump kits for power ratings up to 1000rwhp. We can also accomodate power ratings in excess of this with a pump/wiring upgrade.
Feel free to call with any questions conerning your application.
