Max hp on stock pump and lines
Old 04-24-2013, 06:41 PM
simplysix's Avatar
Default Max hp on stock pump and lines
I couldn't find a good answer by searching. I'm installing a front mount t72 with a 5.8 spring in the waste gate. Expecting 440-460 rwhp. Won't be spun over 6k due to stock internals and rod bolts. Upgraded injectors will be installed (probably 60's) and car will be Dyno tuned. Question is will the stock 2002 fuel pump support that?
I'll upgrade it in the future, but may not have time before I go to the Dyno.
Old 04-24-2013, 07:03 PM
Moon Cricket's Avatar
I'd say you could probably do it, however I'd say it would be on the sketchy side especially for longevity
Old 04-24-2013, 07:22 PM
IMPRTKILLER's Avatar
U would want a Aeromotive 340 pump from summit...they cost $180 but u will need it. As for the lines...stock line can support up to 750 HP but if u had the money -8 AN line is better for that. Then use a -6 AN return line.
Old 04-24-2013, 08:16 PM
simplysix's Avatar
I know It'll need upgraded, I was planning on 255 with harness, I just wanted to find out if it'd be ok/safe to Dyno with the stock pump
Quick Reply: Max hp on stock pump and lines
