Fuel pump replacment question
I recently bought a 99 z28 Camaro that has been upgraded to a ss. it has sit in a garage for 4 years and the fuel pump doesn't work now. I ordered a new racetronix one . but I was wondering if I need to replace the entire module as well? and where I could find just the housing. and the fuel gauge is stuck too I believe.. and advice would be greatly appreciated
No, you do not have to replace the module. The fuel level sender can be replaced.
Remove float arm and the white lock tab, pinch the barbs on top of the fuel level sender together, the sender will slide out.
