Will changing from Venom 60 lbs to Mototron 60lb make a mapping difference?
Old 07-24-2013, 11:24 PM
Banshee Ben's Avatar
Default Will changing from Venom 60 lbs to Mototron 60lb make a mapping difference?
I have a set of Venom and I think they are in need of some major cleaning, last time I had them cleaned they were $300 and it looks like I can get a new set of Mototron's in the 350-400 range, where as the venom is $600.
I don't really have a preference but don't want my map to be messed up. Is a 60lb injector set up to flow that amount regardless of the brand?
Also recommended store to get injectors?
Thanks.
(map if for a boosted motor)
Quick Reply: Will changing from Venom 60 lbs to Mototron 60lb make a mapping difference?
