aftermarket fuel rails pointless with stock lines??
ok I have a fast 92 intake and im about to get the FAST rails also, I know that they have a fitting to connect the stock lines to a -6. is it pointless to buy aftermarket rails if the lines are still stock?
If you measure the ID of the stock feed fuel line it has the same inside diameter as a -8 fitting. Most people go with the -6, I went with -8 on my car with no troubles. Might look into it.
