Oem ls1 fuel rail an adapters
Old 09-15-2013, 02:52 AM
Turboswede's Avatar
Default Oem ls1 fuel rail an adapters
Has anyone here used an adapters on std ls1 fuel rails?
Im wonder about this one for the return line an6
http://www.summitracing.com/parts/rus-644120
And this one for the feeding an8
http://www.summitracing.com/parts/rus-644133
Would they fit?
Old 09-15-2013, 05:01 AM
Ollie8974's Avatar
Yes they will fit.
The adapters with threaded lock collar are an improvement over the older slip lock, that are known to blow off under pressure.
Converted to those when they cam out. not a bit of trouble.
Old 09-15-2013, 09:52 AM
Turboswede's Avatar
Thanks, are those i linked The adapters with threaded lock collar? Sorry im not so good at english
Old 09-16-2013, 05:19 AM
Ollie8974's Avatar
Yes these are the threaded lock collars
1 New style with threaded lock ring.
2 Old style with plastic lock.
3-5 assembly sequence.
Attached Thumbnails Oem ls1 fuel rail an adapters-new-style-screw-lock.jpg   Oem ls1 fuel rail an adapters-old-style-plastic-lock.jpg   Oem ls1 fuel rail an adapters-step-1-russell-efi.jpg   Oem ls1 fuel rail an adapters-step-2-russell-efi.jpg   Oem ls1 fuel rail an adapters-step-3-russell-efi.jpg
Old 09-16-2013, 12:43 PM
Turboswede's Avatar
Great! Thanks for the help
Quick Reply: Oem ls1 fuel rail an adapters
