What Injectors need asap Everyone jump in
I have Edelbrock High ram intake on my 402ci. Going with turbo satup for around 750-800 rwhp. Need injectors that will work with the edelbrock rails and support my goals. Need to know asap since I'm ordering parts in the morning. Its a LS2 PCM and Harness.
I currently have 46lbs fast low independence injectors and not sure what the difference is or even if I could run high independence injectors. The edelbrock fuel rails state I need Bosch, Pico or standard injectors so looking for something to fit and around 90lbs or so.
give Fuel Injector Connection a call. I'm guessing a dual pump setup 255 in tank or a 255 and a 320...give Lonnies a call for the fuel system, then grab some injectors from mentioned company. Likely 725cc or 825cc will be good.
you could also look at the DIY fuel systems shown on here. CV products sells a lot of items/hose, etc.
I'm running a dual 255 walbro in tank pumps with -6an lines with return. 58 psi at the rail. Need standard or pico injectors to work with ls2 computer. Not sure if I can use high independence injectors on my harness?
I'm currently running fast 46lbs low indep. injectors now and switched to turbo setup with edelbrock high ram intake and fuel rail that only uses pico or standard injector sizes. Need help finding 70lbs and up injectors to fit intake and pcm.
so you have a low impedance injector box? pico or standard injector sizes? what about the plug type? EV1 , minitimer, etc.
call Fuel Injector Connection. PCM wise it doesn't matter. you need to find out what the connection type is, how tall they are.
