42# green giant injectors
I recently upgraded my injectors from the stock injectors to Bosch 42# green giant injectors and had the car retuned. I drove the car for about a day and a half and the car developed a miss on cylinder #6. The injector on that cylinder went bad so I contacted the person I bought the injectors from and he sent me a new one. I replaced the bad injector and drove the car yesterday. It ran on all 8 cylinders for the day and started missing again. I felt the header tubes and #6 was cold. I switched injectors and the miss followed that injector. Why would I be having problems with the injectors going bad on #6. The tuner is blaming the injectors but I can't understand why its the same cylinder?
can you put your other injectors (stock or NOT those 42#) and re-tune, and does it have a miss?
Are you absolutely certain the connections are solid and plugged in all the way
Try checking the wiring to the injector. If the same one keeps going bad, there may be a ground somewhere within the wiring for that injector. Might be getting an over-voltage on it, which keeps burning them up.
