nasty performance pro touring tank
Does anyone know how to install the Nast performance pro touring tank into a 98 f-body? I get it set in and the fuel lines on top seem to hit the floor and the tank straps don't seem to work right.
Yep same problem I had. I had to lengthen the straps and order $30 a piece fittings for the tank. The fittings were Fragola brand Summit had them. I can get you part numbers but it will be after 7:00 tonight before I can get them.
Factory straps work just need to be bent to the shape of the tank. Use slightly longer bolts to draw them up. Fittings on top some seem to fit better than others but slight massage of the floor and drops right in.
