Racetronix wire harness install
Old 12-07-2013, 12:21 PM
2QuikTA's Avatar
Default Racetronix wire harness install
I was just curious where everybody routed the harness to the alternator. I have it up the hard lines to the headers so far. Are you following the hard lines all the way up behind the heat shields? Where is the best place to route it at this point?
Thanks!
Old 12-07-2013, 01:05 PM
Undertow74's Avatar
Yes run it along the frame rail behind all the heat shields the up the firewall behind the heat shields also all the way to the alternator. That's what I did
Old 12-07-2013, 01:10 PM
2QuikTA's Avatar
Did you just leave it loose? With the headers in the way there's no way I can get wire ties all the way up to the alternator.
Old 12-07-2013, 01:49 PM
Undertow74's Avatar
Loose tucked behind the heat shields because they are screwed I. And wires won't go anywhere. Then I am trying to think....I think I ran the wire up by the fuse block/abs block to the alternator
Quick Reply: Racetronix wire harness install
