Guys running Wilson 4500 throttle body
Old 12-21-2013, 09:29 PM
josh414's Avatar
Default Guys running Wilson 4500 throttle body
?? Guys running Wilson throttle body i have a 4500 2008cfm one on the way i have a few questions
1. how are the return springs are they adequate alone or is it necessary to run a throttle cable bracket with return springs.
2. what throttle cable bracket did you use
3. post pics of your setup
thanks
Old 12-22-2013, 11:00 AM
Firehawk441's Avatar
http://www.jegs.com/i/JEGS-Performan...oductId=752613
http://www.jegs.com/i/JEGS-Performan...rentProductId=
Old 12-23-2013, 07:16 PM
josh414's Avatar
are the springs on the TB stiff enough alone or was is necessary to run additional spring for proper pedal return and over all feel
thanks for the links
do you happen to have any pics of your setup you care to share
Old 12-24-2013, 10:33 AM
Amac1978's Avatar
That's interesting. I'd do that if I could keep my abs and cruise control.
Old 12-24-2013, 10:37 AM
josh414's Avatar
not many guys running 4500 throttle bodies??
Quick Reply: Guys running Wilson 4500 throttle body
