Bigger injectors loss of 18hp??
Old 02-07-2014, 08:46 PM
6SSPEED's Avatar
Default Bigger injectors loss of 18hp??
I have a 2000 z28 and recently maxed out the stock injectors so I bought some Lucas 38#. Before the injector swap the car was laying down 397hp. I changed the injectors, put bigger headers and a cutout and it dropped to 379hp after being retuned. The Lucas injectors are a pencil type spray pattern injector where as the stock ls1 style is a 4 hole spray pattern injector. Is the spray pattern what's costing me this power loss?
These are the injectors I installed......
Old 02-07-2014, 09:43 PM
Majestic9C1's Avatar
My sources say yes... but dont quote me
Old 02-08-2014, 08:05 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
Not sure since you changed multiple things as 1 time....
Did you use the same dyno.... this is a key factor.
If not the numbers are meaningless.
Did the dyno operator correct for weather conditions?
Do you have a graph of the air/fuel ratio with both sets of injectors?
Did the same person tune it both times?
Larger headers generally help the peak power & lower the low end so they in theory should have raised the peak.
If you really want to know, change the injectors back & retune//test.
Its the only way you'll know
Old 02-08-2014, 12:35 PM
6SSPEED's Avatar
Same tuner, same dyno. Yes, all corrections were made. I know the injectors are the problem but my real question is does the spray pattern really make that much of a difference or is the problem in the injector itself?
Old 02-08-2014, 07:44 PM
RJDio's Avatar
Interesting thread, following it. I'm no where near maxing out injectors, but I just ordered a Racetronix fuel pump with hotwire. I hope to get to a point of maxing out injectors
Old 02-08-2014, 08:48 PM
S10xGN's Avatar
We're they flowed and cleaned, or did you just "stick 'em in" and run with it?
Old 02-09-2014, 08:57 AM
6SSPEED's Avatar
Inspected them to make sure the tips weren't broke but didn't have them cleaned
Quick Reply: Bigger injectors loss of 18hp??
