Help with fuel lines with ls swap
Any ideas on what's the best hose to use? I was thinking of using earls super stock hose. Wanting to go with AN fittings probably 6 fuel/return.
Just trying to see what you'll think.
I liked the idea I don't have to buy special wrenches to use it and it rates 250 psi...
Not sure why it wouldn't work
I am a big fan of Fragola hoses/fittings. Great quality and Made in the USA (to me that is a huge selling point). Pretty much every line/fitting on my fuel system is Fragola.
I can't stress enough how important it is to get PTFE hose. If you don't you will get fuel permeation and you will get a horrible fuel smell which will lead to fuel seeping thru the hose itself.
Russell's ProFlex hose is 50 bucks for 10 feet at -6 AN. Its braided stainless hose thats rated to a couple hundred PSI and compatible with nearly all fuels, including methanol.
Fragola is about $10 more for braided nylon hose of the same size and length.
Either will do the job.
