Injector swap
Old 03-28-2014, 12:54 PM
volvochimp's Avatar
Default Injector swap
I am looking to increase injector size for my lq4 swap project. I am considering a couple of bosch injectors that I can get for a good price: 0280156201 (36#) or 0 280 155 831 (30#).
Harness is not built yet so connector type can be adapted. I am running aftermarket intake/fuel rails so I don't believe height will be an issue either. My question is can I pretty much swap in any high impediance EV1/EV6 multiport bosch injector with sufficient flow? Will a tuner run in to difficulty setting up pcm for either of these?
Old 03-28-2014, 09:26 PM
ZL1Killa's Avatar
if you can either find or get any data on them that would make tuning much easier. Either would work in your setup. I would go more for the 36# to leave some room
Old 03-31-2014, 10:57 AM
volvochimp's Avatar
Thanks Z, I guess I should have asked in the OP: which injector data is actually required by GM ECU/tuner?
Old 03-31-2014, 07:52 PM
ZL1Killa's Avatar
IFR is pretty straightforward, rating @ x PSI, then what are you running them at pressure wise compared to their rating. *look at my fuel & injector sticky, if you don't understand PM me and we can hash it out.
then offset table, short pulsewidth, minimum pulsewidth, a few others
Quick Reply: Injector swap
