walbro 255
Old 03-28-2014, 09:25 PM
Raven02TA's Avatar
Default walbro 255
just got my hands on a pump. dont have a sock or anything else with it. what all usually comes with the pump when bought new? any links to where i can order it from?
Old 03-28-2014, 09:29 PM
HCI2000SS's Avatar
Check out Lonnies Performance
Old 03-28-2014, 09:31 PM
Raven02TA's Avatar
went to their site. no info on buying anything other than a full system, i have the pump. just need the rest.
Old 03-28-2014, 09:35 PM
HCI2000SS's Avatar
Hmmm I would at least talk to Lonnie about that and make sure. It couldn't hurt
Old 03-28-2014, 10:20 PM
NOS LS1's Avatar
You should buy the fuel pump kit & the wiring harness kit also.
I have this on my car & it works great ! It will support 600 H.P.
You really should install the wiring harness upgrade kit that connects to the back of your alternator instead of getting power from your battery like a stock car would. There is more available voltage at the alternator & the upgraded Heavy Duty wiring is really what you need when running the High output fuel pump. It is worth all the work.
This is what you need... & make sure you order the correct fuel pump & wiring kits for the correct year of your car. 1998 kits are different than the 1999-2002 kits.
Read all of this information well before you order your kits.
You can order direct from Racetronix Direct.
Here the Link...
http://www.racetronix.com/RX-F99-FPKG-2.html
Old 03-29-2014, 10:43 AM
a-low's Avatar
Just ordered me some from auto performance engineering for my dual setup.
Quick Reply: walbro 255
