steel braided fuel line fittings?
does anyone know what fittings these quick release are? i want black steel braided lines with black fittings to clean up the engine bay a bit and get rid of the nasty foil covered junk. im new to the steel braided and an fitting stuff so go easy on me . huron speed sells a kit like this but only in the regular steel braided
![](http://i102.photobucket.com/albums/m110/justinktm/13893671311601659835192_zps0b19e6a0.jpeg)
I purchased and received this kit, the connector does not fit the evap purge valve even though it says no modification required!
The male connection is too short resulting in the female connector not clicking into place, it will slide straight off! I've ordered the new russel connectors part 644123 and 644113 in the hopes it will fit plus give a safer connection to the other hoses.
How did the 644123 work for you? I tried putting it on my factory return, feed, and evap, it wouldn't fit any, the male end was too short.
The Russel fittings are made in various sizes.
http://www.summitracing.com/search?S...EFI%20fittings
You didn't look very hard. Something like this, only straight,
http://www.summitracing.com/parts/rus-611260
This is the straight one although there is no photo.
http://www.summitracing.com/parts/rus-611200
The Russel fitting uses that little horse shoe shaped piece to hold it on the line. That works pretty good. But if you're racing, they tend to fall off due to the vibration.
Flyin' Miata has a custom made connector that screws together. Much more secure. It's not listed on their site, you just have to contact them.
