Dual Walbro 450s with stock bucket COMPLETE
I searched high and low on how to make these pumps work on an Fbody (2001) or if it was even possible with the factory tank and factory hanger/bucket and had no luck. So I took it upon myself to make a thread to show it's possible/doable to get these to fit with small modifications and a lot of patience. The hardest part was fitting the socks into the tank as the plastic part holding the sock on to the pump has almost no give or flex to it. Pair that with the bottoms of the 450's being wide at the bottom, and you're in for a hell of a fight to get it into the tank, but its 100% doable.
I wired them so they both run at the same time, no hobbs switch. And I ended up moving the relays into the spare tire well since I decided to relocate my battery as well. Here are a few pics I took along the way.
