New injector/pump questions
I need new injectors for my build. Apparently my stock ones are at 110 duty cycle at 5600 rpms? This is Japanese to me... I know very little about this stuff. My mods are listed in my signature.
What injectors can I use and do I need a fuel pump as well?
Thanks!
Thanks!
You can get the Racetronix pump/hotwire kit. I believe it will have everything you need for the swap. Change out fuel pump and injectors, then get it retuned. You could probably get everything for under $400, even cheaper if you get a deal on some injectors.
