regulator by fuel filter
Old 05-24-2014, 01:40 AM
stangtrader's Avatar
Default regulator by fuel filter
Alright heres my problem, my stock intank regulator housing on my twin turbo camaro broke and I have a external bosst reference regulator I was going to put on down the road with a new 6an return, however my tank is currently full and need a solution. I seen it mentioned and seen it done but I have no clue what fittings I need.id like to put my regulator in place of the t block under the car next to the filter . anyone know part numbers of the needed fittings to adapt, or will I need to cut and flare the lines and use tube nuts with adapter fittings.ive been searching but not having luck
Quick Reply: regulator by fuel filter
