8an supply W/6an return horspower limits?
Old 06-27-2014, 10:56 AM
mike13's Avatar
Default 8an supply W/6an return horspower limits?
Will 8an fuel line from tank to rails with a 6an return support 1400-1500crank horsepower on E85?
Switching to larger injectors to lower my base fuel pressure to 40-45psi, boost referenced and need to find out if my current hoses need to be upgraded to 10an & 8an.
Old 06-27-2014, 03:05 PM
No Juice's Avatar
I'd like to know as well
Old 06-27-2014, 03:25 PM
2000SS1979's Avatar
I know it's good for 1,100RWHP for sure with room to spare on E85. So I think it would handle your power goals at the crank.
Old 06-27-2014, 05:22 PM
mike13's Avatar
Thanks
Old 06-27-2014, 06:29 PM
No Juice's Avatar
How about some more info on the set up ?
It will of course depend on pump.
Old 06-27-2014, 09:16 PM
2000SS1979's Avatar
It was a local guy that did it. Twin 450's, 127lb injectors. Here is his dyno thread. In it there is a link to his build thread.
https://ls1tech.com/forums/showthread.php?t=1727825
Quick Reply: 8an supply W/6an return horspower limits?
